Laptop fan repair
Discussion in 'Troubleshooting and Repair' started by mac12, Jul 3, 2015.
  1. mac12
    mac12
    13
    Jun 22, 2015
    I was just testing the laptop internal cooling fan with external battery it was working fine.,,but suddenly after few test it is not working ? i also removed and cleansed the inner parts, but still does not work ? is it repair able...
    it has 3 wire yellow, black and red ...
    Please suggest ...
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    What battery did you use to test, and which wires did you connect it to?
    The black is ground , the red is power, the yellow is either a pwm control, or rpm signal. (cant remember)
    If you damaged it you will need a new one, unless someone here can magically show you how to disassemble the fan, test the coils on the armature. Something is wrong, but whether you can fix it is another story. If it were me, I'd toss it and buy a new fan.
  3. mac12
    mac12
    13
    Jun 22, 2015
    fine.
  4. Edwardw35
    Edwardw35
    21
    Jun 16, 2015
    I think you are not fit correctly, check again your laptop...
