Laptop charger adapter
Discussion in 'Troubleshooting and Repair' started by Ga.Pal, Jan 25, 2014.
  1. Ga.Pal
    Ga.Pal
    Jan 25, 2014
    Hi everybody, this is my first post here and let me start by greeting all of you.
    I would like to repair my old laptop charger adapter. I already have bought a new one, but since this is original it would be nice to repair it.
    When I try to plug the charger (not into my laptop) it start to beeping. I have read that I might be a bad capacitor inside the charger that causes this noise. This beep comes from the amaranth capacitors (I think). First of all, I am not an expert on this matter, but I would like to know:
    1 is it possible to repair it?
    2 what is that with stuff inside the charger? Does it come form from same kind of leaking?
    I hope you can help me
    http://s7.postimg.org/czivbhykr/adapter.jpg
  2. davenn
    davenn Moderator
    13,837
    1,952
    HI Ga.Pal
    welcome to the forums :)
    The white stuff is just silicon sealer to stop particularly the heavier components moving around.
    capacitors dont beep,
    amaranth capacitors .... no such thing that Im aware of ... nothing on google
    the 2 output electrolytic capacitors on the right side look OK ... they are not bulging
    the other is that big brown one in the middle.
    you could replace those 2 right hand ones and see if it solves the problem
    they do commonly fail in plugpacks
  3. (*steve*)
    25,497
    2,838
    1) Switchmode controllers are possible to repair, but the repair may be difficult and working on them can be dangerous.
    2) the white stuff is used to prevent things vibrating and making noises, or potentially stressing solder connections and breaking. It does not come from anything leaking (Yep, it's supposed to look like that)
    What does "amaranth" mean?
  4. Ga.Pal
    Ga.Pal
    Jan 25, 2014
    Thanks for the prompt answers.
    I will try to replace the 2 capacitors. Is ti worth replacing the brown capacitor?
    It's seemed to me that the beping sound come from the brown capacitor.
    After that we'll the Switchmode controllers.
    Amaranth. Reddish brown.
