laptop ACadapter barrel plug polarity simbol?
Discussion in 'Electronic Design' started by Tim Wescott, Jun 4, 2005.
  1. Tim Wescott
    Tim Wescott Guest
    That just means it's DC; if there's any polarity markings they'll be
    seperate.
  2. Orc General
    Orc General Guest
    What's the barrel plug symbol means when it has a solid line on top and a
    dashed right under it? Is that ot say the barrel plug has the inside
    cylinder as negative and the outside positive? or is it hte other way
    around?
  3. Richard H.
    Richard H. Guest
    Neither. IIRC it means the input needs to be *regulated* DC power (not
    a wall wart).
    Usually there's another indicator like a C with a dot in the middle
    (i.e., the end of a barrel connector), with one of them showing + or -.
    That's your polarity marking.
    Richard
  4. Pooh Bear
    Pooh Bear Guest
    Hey - some wall warts *are* regulated DC.
    Did you mean 'it isn't AC' ?
    < picks up ADSL modem > Only if the manufacturer can be bothered ! There's
    nothing on the back at all.
    Graham
  5. Richard H.
    Richard H. Guest
    Should've said "most" wall warts. Nearly all the wall warts I come
    across (i.e., consumer goods) aren't regulated, though there are
    certainly exceptions like the one you mentioned. (IME most regulated
    supplies tend to be inline bricks for some reason, like laptops.)
    Cheers,
    Richard
