C
Charlie Edmondson
Yaknow, Jim, I think the problem is the automatted test equipment. itJim said:I _knew_ it had to be water... anytime it rained my "line lights"
would start to glimmer. And I could measure the drop with my DVM.
But they didn't do squat until the tech I knew showed up.
...Jim Thompson
tests and records the line every night, so it establishes a baseline.
then, you get something that takes a few weeks to get in there, and it
slowly moves the baseline. Then, finally, it starts effecting things,
but the test gear says everything is okey-dokey...
It is only when you have someone actually MANUALLY take a look at the
line that he notices the tip ground...
Charlie
