Lamp part repair
Discussion in 'Electronic Repair' started by ssylee, Jan 22, 2008.
  1. ssylee
    ssylee Guest
    I'm planning to repair the lamp as shown in http://imagebin.ca/view/rQE4qg8b.html
    .. I'm confused what's the black part called as I suspect that
    particular part is the culprit of the light bulb not turning on (the
    light bulb is brand new and the contacts looked burnt). Any
    suggestions would be most welcomed. Thanks!
  2. Guest
    Socket.
    Can be found in various iterations at Home Depot. If you can afford
    it, get one that is ceramic vs. bakelite or plastic.
    http://www.mylampparts.com/index.php?cPath=175_655_687 if it will
    fit. Otherwise:
    http://electrical.hardwarestore.com/13-39-lamp-sockets/keyless-bakelite-socket-600380.aspx
    http://electrical.hardwarestore.com...candescent-medium-base-fix-socket-622656.aspx
    Mind the exposed connections on the back of it, especially if that is
    a metal housing. You may have to transfer the cover cap from the old
    one.
    Peter Wieck
    Wyncote, PA
  3. James Sweet
    James Sweet Guest
    The socket?
    It's easy enough to do, however if you have to ask what it's called, I
    suggest you do some reading or get someone experienced to help you, or just
    buy a new lamp. Done wrong it can be a shock or fire hazzard.
    Google replacing a lamp socket, there should be some DIY resources out
    there. Any hardware store or book store will have DIY electrical or general
    home repair books will have pictures and instructions for tasks like that. A
    book is a good investment that you can use for other projects too.
  4. mc
    mc Guest
    Wise advice. I always tell people that their very first electronics project
    should not be something safety-critical.
  5. mc
    mc Guest
    Also, it could be a very quick job for an appliance repair shop.
  6. Tov
    Tov Guest
    You haven't been using a higher-rated bulb than the lamp can take,
    have you?
