L298 question.
Gav1985
Mar 12, 2013
18
Mar 12, 2013
18
Hi guys, I'm using an L298 H-Bridge and I have general query.
The chip has a VSS and Vs pin. VSS = VDD = 5V.
It states that VS should = VDD + 2.5V upto maximum of 50V with the motors also connected to this rail.
So VS should equal min 7.5V. I'm going to use a 7.2V battery (close enough) which I have connected to the motors and output diodes etc, but I've connected Vs to 5V instead of the 7.2V.... :facepalm:
Will the motors turn? Or will I need to connect Vs to the 7.2V.
I haven't been able to test it yet and this is my first time using an H-Bridge.
https://www.sparkfun.com/datasheets/Robotics/L298_H_Bridge.pdf
The bottom of page 6 on the datasheet shows an example of how i've connected up the H-Bridge with the exception of Vs as I've mentioned above.
Thanks all.
Gav1985
Mar 12, 2013
18
Mar 12, 2013
18
I bit the bullet, I reconfigured the Vs line so that it too is connected to the 7.2V rail. No need for replies.
Thanks to those that looked anyway.
