Welcome to our forum.
Unfortunately, your answer is not correct - at least as far as I understand it. Assuming that Vo(0+) is the output voltage for the time where Vi=0V, then how and why should it be influenced by "E" at all?
If the assumption is incorrect, then Vo(0+) makes no sense.
You need to find an expression for Vo=Vo(t)=f(E,t) where t=time with t=0 at the moment of the step change (this is for ease of calculation, you can set t=0 anywhere, but the expression becomes slightly more complicated). f(E,t) will contain terms using R1, R2 and C1 (the capacitor is missing in your equation).
You will need to use the relation I(c)=C*dv/dt or equivalently V(c)=1/C*integral(i(c)*dt).
To get a feeling for the circuit imagine the two following operating conditions:
- what happens if Vi is a DC signal? What effect has this on Vo?
- what happens if Vi is a high frequency AC signal? Consider the impedance of C1 for high frequencies and its relation to R1, R2. What is Vo (in a first approximation)?
