KYZ relay contacts on meter?
Discussion in 'Home Power and Microgeneration' started by William P.N. Smith, Jan 15, 2004.
  1. I've got an electrical KWHR meter with "KYZ" pulse outputs every 10(?)
    watts, what exactly does that mean? Is it just NO, C, NC, or
    something more exotic?
    Thanks!
  2. SQLit
    SQLit Guest
    KYZ in my experience has always been open closed for a time then off again.
    Sort of like a square wave.
    You estimation of the 10 watts I would bet is wrong. I have used KYZ as kwh
    and kwdemand. The scaling I have seen is something on the order of 1000kw
    to 10000 kw. You will need a pretty fast, nothing exotic real time clock to
    count the pulses. The speed at which the pulses come in can vary. Some time
    the amplitude of the pulse makes a difference.
    Have fun with your new toy
  3. I didn't really say that, did I? 8*} I meant 10 watt-hours, I think.
    It's a GE KV2 meter if that matters...
  4. SpiderG
    SpiderG Guest
    According to the Edison Electric Institutes 'Handbook for Electricity
    Metering':
    "The output pulses are normally Form C closures, commonly known as KYZ or
    double throw, single pole or their electrical equivalent. each closure is
    one pulse."
    "... in a receiving instrument which counts the number of pulses, this
    count, multiplied by the primary watthour constant, gives the value of the
    energy measured."
    It is typically used in remote telemetry or totalization implementations
    (sub-metering for example).
    The text goes on for another page, but I'm not a goot typist...
    HTH
    Glenn
  5. Ah, OK, so it's SPDT, so if it's really relay based you can easily do
    switch debouncing. I was afraid it was some wierd quadrature thing so
    you could tell which way the energy was flowing, which would be more
    difficult to count.
    Thanks!
