Kustom organ repair of funky contacts
Discussion in 'Troubleshooting and Repair' started by Tomasm53, May 8, 2017.
  1. Tomasm53
    Tomasm53
    May 8, 2017
    I have a Kustom organ from the '60's. It had Tabs on it that make and break contact with a bar to turn on and off different tones. The contact is a "spring-like" piece approximately 3/8" long. The little metal bar comes up from the pcb in one hole and back out in another hold. When the tab is actuated it has a lever system that brings the "spring-like" contact into contact with that bar to complete the circuit. The little metal bar looks like a tiny hitching railing for horses.
    The weakness in this system is that the "spring-like" contacts break with wear and tear. They are soldered into the board. Does anyone know where you can find this type of contact?
  2. (*steve*)
    25,412
    2,780
    A picture would help, but presumably these switches were made to a price (cheap).
    You may be able to replace them with a lever operated microswitch or similar.
  3. Alec_t
    Alec_t
    2,892
    776
    Jul 7, 2015
    As well as a picture, dimensions would help too.
  4. Harald Kapp
    10,382
    2,267
    and in addition custm made for this organ.
    You may be able to built ones yourself from strips of phosphorus bronze?
