Know how
Discussion in 'Electronic Basics' started by Wong, Jun 24, 2004.
  1. Wong
    Wong Guest
    Debugging using Hyper Terminal is interesting. I know that
    microcontroller communicating with HT through RS232, but what is the
    "character format" that HT using ? i.e. how HT know that the micron is
    sending an "A" ?
    Is this "A" represented in ASCII value, 0x41 and micron send out
    0x41 to HT?
    Thanks in advance.
  2. Zorknob
    Zorknob Guest
    Yes. HT uses the ASCII character set.
  3. Jorkoy
    Jorkoy Guest
    What type of serial port and cable do you use?
    Jorkoy
  4. Wong
    Wong Guest
    Com Port and Standard DB-9 cable.
