knobs for 1/8" shaft dia.
D
Dave Boland
I need some decent pointer knobs for pots with 1/8" (inch)
shafts. Have found some, but too large and tooooo expensive
(>$1.80 each). Anyone got a good source for these or other
good idea? Heck, even the 1/4" to 1/8" converters are
expensive. Ain't miniaturization grand??
R
RST Engineering \(jw\)
We had the same problem with 5mm shafts and 1/4" knobs. We would up
drilling out 1/4" #8 spacers to 5mm. You might consider drilling out
1/4" rod and supergluing it to the small shaft.
Jim
D
DaveM
Dave Boland said:
I need some decent pointer knobs for pots with 1/8" (inch) shafts. Have
found some, but too large and tooooo expensive (>$1.80 each). Anyone got a
good source for these or other good idea? Heck, even the 1/4" to 1/8"
converters are expensive. Ain't miniaturization grand??
http://www.mpja.com/listitems.asp?dept=154&main=110
http://www.allelectronics.com/cgi-bin/category.cgi?category=310&type=store
Dave M
MasonDG44 at comcast dot net (Just subsitute the appropriate characters in
the address)
Never take a laxative and a sleeping pill at the same time!!
P
Pooh Bear
http://www.sifam.co.uk/collet_intro.lasso
Graham
R
Ron G
I make my own by filling an empty toothpaste cap with epoxy.
I drill it out, drill and tap a side hole for a small set screw.
I've been doing this for 30+ years.
Makes a nice, narrow profile knob.
Best----
Ron
Jim Thompson
Best----
Ron
Helluva good idea!
...Jim Thompson
H
Hans-Bernhard Broeker
In said:
Mine all have tooth-marks in them from opening the tube with my
teeth... :)
It shouldn't have to have those ;-)
I like the laboratory workers' way of opening this kind of container
with only one hand: hold the tube with the "lower" 3 fingers, then use
thumb and index finger to unscrew the top. Trains your dexterity
quite a bit --- which may come in handy next time you have to solder a
wire in the field, with no "third hand" tool at hand, so you have to
manipulate 3 or 4 objects with only two hands ;-)
D
Dave Boland
got a good source for these or other good idea? Heck, even the 1/4" to
1/8" converters are expensive. Ain't miniaturization grand??
Thank you all for the help. I'm especially amused at the
idea of using a tooth paste cap. My problem is that my cap
is a pop open
(http://www.colgatetotal.com/app/ColgateTotal/US/Products.cvsp )
So I was wondering if I could make a cap from a wine cork
(have a few of those)?? :)
Dave,
R
Rich Grise
Thank you all for the help. I'm especially amused at the idea of using a
tooth paste cap. My problem is that my cap is a pop open
So I was wondering if I could make a cap from a wine cork (have a few of
those)?? :)
I can't think of any reason why not, other than how well it can grab
the shaft - I wonder if there's some kind of plasticizer - or maybe
drill a 3/16" hole, fill it with epoxy, then drill out the epoxy to
1/8". And leave the outside just cork - over the years, the knobs
will "acquire character." ;-)
Cheers!
Rich
