gottuhaveit
- Oct 27, 2017
- 4
- Joined
- Oct 27, 2017
- Messages
- 4
I am attempting to replace what I was told is an internal fuse for my knife sharpener which is powered by 110 volts but I actually am not sure what it is or where I can get the electrical component to replace it. I checked the component for continuity and it has none so I know if it is a fuse that it has blown. I was sharpening a lawnmower blade with the sharpener and the sanding belt came off the sharpener and got bound up. After that the sharpener quite running and will not run now. I took the sharpener apart and found the bad component inside it but have no idea where I can find one to replace it. There is writing on 2 sides of the component. On one side it has CQ3AM2 and on the other side it has CRU3A. I will upload some pics of the component and the wiring for my knife sharpener. I would certainly appreciate any helpful input concerning this matter and I thank you in advance.
