Kitchenaid Microwave Wont Heat!
Discussion in 'Troubleshooting and Repair' started by michael kali, Jun 19, 2017.
  1. michael kali
    michael kali
    Jun 19, 2017
    MODEL KCMC1575BSS, UNIT IS 2 YEARS OLD AND ALL FUNCTIONS WORK BUT NO HEAT CHECKED MOST PARTS BUT WAS WONDERING COULD A DOOR SWITCH PREVENT HV TO THE MAGNETRON AND NOT CAUSE OTHER ISSUES?
  2. davenn
    davenn Moderator
    13,866
    1,958
    it may be that or it may be that the magnetron has failed
    regardless you should take it to a qualified service centre if you want it checked
    OHH and please don't type everything is caps .... ie turn your caps lock off
    on the net using caps means you are shouting
  3. michael kali
    michael kali
    Jun 19, 2017
    thank's Dave, checked the magnetron only issue was loose cooling fins, will try pulling door switch.
