mikeBeginner
- Sep 21, 2011
- 5
- Joined
- Sep 21, 2011
- Messages
- 5
Hi. novice here.
I am wiring a relay w/ kitchen hood: it will first power-open a damper before the
fan can get power to run. It spring closes. The hood has lights, that are independent of the fan, ie their own on/off.
Problem: the wire I need to tap, to route thru my relay is always 'hot', even when the fan is off.
So - as soon as I plug in the fan (but not even turn it on), I watch as line voltage goes from this wire, to my 24VDC transformer, to feed both the relay and the 24VDC power-open damper. The damper opens, etc.
What would I see if I open the fan housing?
Can I open up the fan housing and hopefully find a spot that is 'after' the on-switch that I can tap?
My diagram:
http://www.kitchenhoods.ca/catalog/images/Wiring218-1.jpg
Disregard 12V transformer. My model has GU10 line voltage (not MR16s). Lites ARE independent of the fan.
My hard-copy drawing also notes:
Brown-4-fanSpeed 6, Green-5-fanSpeed 5, ..., down to Blue-9-fanSpeed 1.
Again- my problem is that the black wire (2nd one down) is hot always -
Do you think I can I find a point inside the fan housing where I can be 'after' the on-switch ?
I saw johndearmond.com pic where 'variable speed' wires were wrapped into the innards - I'm hoping my hot wire has some clean connections?
(Chinese made, no info on the motor; Seems like Id open sides of the fan to look for the wire - ie no nice entry where the wires enter the housing.
Thank you for advice.
My diagram:
