Kipor 6000 Inverter Gen KGE6000 TI
VT-CDN
Jul 21, 2019
3
Jul 21, 2019
3
Well the story went , original owner used it once , and he said after power outage he didn't use it till the next outage and then it didn't put out any power. I bought it for 175.00 due to having clean oil and looks new.
Im assuming that if he did the dead mans cord back feeding and if power came back on , Board is toast .
I don't really know what went on , but I do have a Kipor 3000W inverter gen set and it's very reliable .
So no warranty
VT
VT-CDN
Jul 21, 2019
3
Jul 21, 2019
3
I have a Kipor model KGE 6000 TI, Ohm out the twin stator 3 wires both legs all in the same range . Fired and ran idle 125-130Vac close between all a,b,c,,on both sides , revved to 480Vac and the same AC volts close between wires A,B,C from stator . Permanent magnet , as You can feel the pules on manual turning it over .
Tomorrow , Ill do a hot run with board installed and see where I stand .
I haven't found any wiring Dia , and not one hotspot or smell , They have an internal breaker in the board I read .
On my 3000 kipor , I overloaded it and the light came on , power stopped , shut down , restart and all is reset .
So now I fire up one freezer at a time till all 8 are in cycles .
TIA folks
VT
