Kid's battery operated car stopped moving
Discussion in 'General Electronics Discussion' started by wakilnikzad, Apr 14, 2020.
  1. wakilnikzad
    wakilnikzad
    6
    Apr 14, 2020
    Power button of my kid's battery operated car jammed and I replaced it with a new button. Now the car starts but does not move. Neither with the remote control nor with the pedal.
    I know the car starts because the sound of starting engine plays out and all the lights turn on. Also, the horn button and the music player work fine.
    I did the following but found no solution:
    • Checked the batteries. They seem ok and fully charged.
    • Check all the wirings for any cut or loose connection. Everything seems ok.
    • Tested all 3 motors (1 for steering wheel and 2 for rear wheels) by connecting each directly to the battery. All 3 rotate normally and seem ok.
    • Checked the control board for any sign of damage or burn but found nothing.
    With its old power button, the light inside the power button used to remain on/red, but now the light starts for a couple of seconds and goes off.
    When I replaced the power button, I noticed 3 wires. I guess 2 of them are for the power and 1 is for the light inside the button.
    Any help would be appreciated.
  2. Tha fios agaibh
    Tha fios agaibh
    2,156
    725
    Aug 11, 2014
    Post model number and pictures.
  3. Bluejets
    Bluejets
    4,772
    1,000
    Oct 5, 2014
    Guessing replacement switch is momentary.
  4. wakilnikzad
    wakilnikzad
    6
    Apr 14, 2020
    These are the photos of the car
  5. Martaine2005
    Martaine2005
    3,420
    928
    May 12, 2015
    Nice pictures..
    But I think @Tha fios agaibh meant pictures of the old switch and new switch. Plus how you are connecting it.
    A simple diagram of the complete circuit would be useful too including colours of cables.
    Martin
    wakilnikzad likes this.
  6. shrtrnd
    shrtrnd
    3,816
    518
    Jan 15, 2010
    I'm thinking along the same lines as Bluejets and Martaine2005, maybe that switched with the 3 wires was replaced with an incorrect equivalent(?).
    I will mention though, having worked on my grandkids cars, that after figuring-out if your switch is the actual problem or not, if you STILL have a problem, take a look at all that plastic gearing to make sure something isn't hung-up mechanically.
  7. wakilnikzad
    wakilnikzad
    6
    Apr 14, 2020
    Thanks for your openion,
    Actually I couldn't found similar switch (for 3 wires, 2 for the power and 1 I believe for the small lamp inside the button to show it is powered on/off). So I replaced it with a 2-wire switch. I have attached some more photos with the details of what I have done.
  8. wakilnikzad
    wakilnikzad
    6
    Apr 14, 2020
      File size:
      153.2 KB
      10
      File size:
      225.5 KB
      10
      File size:
      182.1 KB
      10
      File size:
      129 KB
      10
      File size:
      87.6 KB
      10
      File size:
      498.1 KB
      10
      File size:
      358.4 KB
      10
  9. BobK
    7,682
    1,688
    And how did you wire the new switch. The fact that there are two wires (red, blue) going to the third terminal makes me think there is something more going on there than just a lighted switch.
  10. wakilnikzad
    wakilnikzad
    6
    Apr 14, 2020
    Connected 2 wires (1 which I guess is fir the light and 1 for the power) to one leg and 1 to the other leg. With the new switch the car starts, the headlights turn on as normal and the music player also works, but the car does not move. Neither with the remote control nor with the pedal. The remote control does not rotate the steering wheel either.
  11. wakilnikzad
    wakilnikzad
    6
    Apr 14, 2020
    When replacing the power switch, I noticed that the original switch had a sign of burnt inside it and one of the legs had melted the plastic a little bit, so it was jamming. Also, I remember that the car was connected to power to recharge its batteries for almost 24 hours. That could have caused the problem.
  12. BobK
    7,682
    1,688
    I think the new switch should go between the two red leads that went to one original terminal and the red and blue leads that go to another terminal. If you used the black lead in wiring the new switch I suspect that is wrong.
    But please do not make that change without further investigation, you could damage something if I am wrong.
    Can you tell me which wires you connected to each terminal of the new switch.
  13. Bluejets
    Bluejets
    4,772
    1,000
    Oct 5, 2014
    Since the board is show in photos I take it that is where the switch in question connects..??
    Can you make the #5 photo larger same as you did with #6 photo..?
    Show the original switch board end connector with wiring.
    Details shown on photo #7 could be correct under certain circumstances so not related to the switch.
