B
bruce varley
Hi, My nephew is 10, mad keen on electronics. What minimum age do people
think is appropriate for owning a soldering iron?
bruce varley said:Hi, My nephew is 10, mad keen on electronics. What minimum age do people
Agreed. We all learn how hot the tip is the hard way ("The man who neverDaniel Watman said:Depends how careful he is and how worried his parents are...
I got my first soldering iron when I was about 7, but only used it with a
parent there at first. It is likely that at least minor burns will occur
unless he is a very careful person. I thought I was pretty careful but still
burned myself quite a few times (once right across 4 fingers). I think 10 is
ok with an adult in the vicinity.
Daniel
Ken Taylor said:Agreed. We all learn how hot the tip is the hard way ("The man who never
burnt his fingers never made anything!") so for a youngster supervision is
really a must for some time.
Ken
bruce said:Hi, My nephew is 10, mad keen on electronics. What minimum age do people
Heywood said:I had a close call when I was about 13 when I was installing an alarm system
to my room. I was soldering two wires together at ceiling height and a blob
of solder fell onto my face about 2cm away from my eye!! From then on dad
made me wear eye protection every time I soldered. That lasted about a
couple of months before I reverted back to no eye protection.
One thing I am a little worried about is lead poisoning. For many years, my
bedroom had all of my electronics in it and I would often not wash my hands
after working with solder. Also, it wasn't an ideal place for solder fumes
either. It must be stressed that lead is terrible for the health of
especially younger people, so make sure the message gets across and stays
that way. I'd recommend a designated area- not a bedroom and not the family
table- for soldering.
more than 20W.
Roger said:Rosin flux fumes gradually sensitise the lungs, eventually producing
instant asthma at the faintest whiff of rosin fume. Once sensitised,
a person basically cannot solder ever again, unless they
have fantastically good fume extraction.
instant
asthma at the faintest whiff of rosin fume. Once sensitised, a person
basically cannot solder ever again, unless they have fantastically good
fume
extraction. TAFE and Uni and many workplaces use good extraction to
prevent rosin sensitisation. You can get extraction at the iron,
extraction
by a "funnel on a pipe" and extraction by fan with absorbent pad. I
also
recommend low flux solder - not the stuff from your local retail shop -
low
flux solder produces remarkably little fume and works OK provided you
are
not soldering tarnished old component leads. Farnell and RS etc have a
range of low fume solders.
If you Google for *Solder Fume* you can find more.
As far as lead exposure goes, always wash the hands after working with
solder and before meals. I recommend plenty of soap and a scrubbing
brush
for the fingernails. If your nephew is a nailbiter, you will have to
enforce nail scrubbing after soldering.
I have been soldering since my childhood, and as a result I have
permanent
asthma and basically cannot solder anymore. And I knew nothing about
lead. In those days nobody gave safety a thought.
Roger
