keychain remote controls
Discussion in 'Electronic Design' started by [email protected], Jun 25, 2006.
  1. Guest
    I recently installed two electric gate openers on a gated drive. The
    remotes work fine, but have a limited range (200 - 300 foot). How can
    they be modified to transmit a bit more power to open gates at 500 foot
    distance?
  2. Increase the sensitivity of the receiving part of the system by
    designing proper antenna at the working frequency.
    Any ARRL book will be helpful.
    The remotes work from button batteries so increasing their transmitted
    signal is more work than it is worth.
    On the other hand if you are on "sci.electronics.design", I have seen
    gates operated by phone, so you ring from your mobile the number of the
    gate, from whatever distance, the gate opens, detects passage of car and
    closes. Or closes after some time delay when NO car passes.
    The ball is in your court;^)
    Have fun
    Stanislaw
    Slack user from Ulladulla.
