kenwood reciever
Discussion in 'Electronic Repair' started by [email protected], Apr 19, 2007.
  1. Guest
    i have a kenwood KR-V6010 IT STARTED OUT THAT YOU WOULD HAVE TO LET IT
    WARM UP BEFORE IT WOULD WORK THEN IT JUST STOPED WORKING ALTOGEATHER
    IT LIGHTS UP AND EVERY THING THERE IS JUST NO SOUND ANY IDEAS?
  2. Meat Plow
    Meat Plow Guest
    Haul it into a local repair shop and get an estimate.
    #1 Offishul Ruiner of Usenet, March 2007
    #1 Usenet Asshole, March 2007
    #1 Bartlo Pset, March 13-24 2007
    #10 Most hated Usenetizen of all time
    Pierre Salinger Memorial Hook, Line & Sinker, June 2004
    COOSN-266-06-25794
  3. James Sweet
    James Sweet Guest
    Cracked solder joints most likely, could also be a dried up electrolytic
    capacitor, it'll take some troubleshooting to figure it out, would have
    been a lot easier if you'd had it looked at when it first started acting up.
  4. Sofie
    Sofie Guest
    Time to take it to a qualified and trained tech with the required test
    equipment and knowledge of how to use it.
    Usually things don't "heal" themselves.... they just get worse and more
    expensive to fix.... the best time to take it in for repairs is when it
    first started showing symptoms... and was still working when warmed up.
    BTW.... is your "caps" key stuck on? .... and what happened to your spell
    checker??
    Daniel Sofie
    Electronics Supply & Repair
