Hello,
Normally I can determine the cause of a problem on my own, but so far anyway..I can't seem to correct the issue I'm having with my kenwood receiver. I've had this for quite a while, and while it's not a top of the line model, it has performed what I needed from a receiver. The problem I'm having with it is that I can only control the functionality of it with the factory supplied remote. When it was new, I could manually press the function key's ( power, tuner, video, etc.) and the desired function would work like it was supposed to. Then, along came some universal remote's that were supplied by various supplier's ( comcast, logitech harmony # 300 & # 650 ), using those remote's I could operate my receiver along with other device's, such as tv-cable box-dvd player, etc. . Now when I try to control the function's manually like I used to be able to, I can't. No matter which function button I press( power,etc.) nothing happens. I can only control the function's by using the factory remote. it's like the function button's are been restricted by being used manually. I've tried resetting the micro computer inside the receiver like is described in my owner manual ( disconnect from power, press the 'tuner' button and while holding it down, plug it back into power). Trying that procedure didn't fix my problem, does anyone have any suggestion's so I can enjoy my receiver normally once again ?/
David
David
