JVC VCR belts
Discussion in 'Electronic Repair' started by Tom Del Rosso, May 7, 2008.
  1. Who sells a belt/tire kit is for a JVC hr-vp830u?
    I find a few belts that x-ref to it, but maybe not all of them, and no
    wheels or tires.
    Thanks.
  2. BH
    BH Guest
    Have you tried JVC Service Dept?
  3. At http://www.jvcservice.com/store/ they sell remotes and cables and such.
    I didn't try calling them though.
    MCM has some belts, but I think a rubber idler wheel might be the problem.
    I thought there would be a kit with the whole set.
  4. Mr. Land
    Mr. Land Guest
    A long time ago there used to be an outfit called PRB - they carried
    all sorts of replacement belts and pulleys...but I think I remember
    seeing a post here that they were bought out by another company.
    Sorry, I can't remember the name.
    Also, at the risk of stating the obvious, have you tried rubber
    cleaner/reconditioner fluid?
  5. Never heard of it actually. Thanks. Google finds rubber stamp cleaner
    (maybe the same?) and a guy who recommends GoJo hand cleaner. Do you know
    another product?
  6. James Sweet
    James Sweet Guest
    I have some stuff called Rubber Renew, it works pretty well.
  7. b
    b Guest
    Don't waste time with 'rubber repairers'. if the rubber is on its way
    out, you're just putting off the inevitable. for a reliable fix
    replace the parts.
    Molgar have them, as do (i think) SEME and CHS
  8. b
    b Guest
    fair point - I have successfully resurfaced rubber idler tyres and
    rollers, ( in vcrs, printers etc) often by just giving 'em a once-over
    with fine sandpaper or an emery board. On more serious cases , on
    especially hard-to-find parts (like idler drive 1960s record players)
    putting the part in a lathe to rotate it 'evenly' as you 'sand' it is
    a good way.
    Anyway i digress - since we're talking belts here, I have found these
    to be far less likely to respond well over the long term to
    'rejuvenation' - best to replace, they're generally far cheaper than
    idlers anyway
    -b
  9. whit3rd
    whit3rd Guest
    Automotive brake fluid is a good rubber cleaner/conditioner.
    Wipe on, wait a day, rinse off excess.
    Aged rubber will oxidize and crack, the conditioner won't always
    bring it back.
  10. GMAN
    GMAN Guest
    Try here
    http://www.studiosoundelectronics.com/
