jvc tv repair
Discussion in 'Electronic Repair' started by David Hutchins, Sep 12, 2003.
  1. I have a JVC AV27795 tv which the audio is out on. There is no sound on the
    built in speakers or on the speaker outputs on the back of the tv. Is this
    a common problem that can be easily repaired?
  2. Jeroni Paul
    Jeroni Paul Guest
    Check if there's audio in earphone jack. I once had a Sony TV with no audio,
    and turned out the earphone jack contact, that passes sound to output
    amplifier when nothing is plugged, were oxidated and didn't make contact.
    David Hutchins expuso:
