JVC TV C-2018, add channels to memory
Discussion in 'Electronic Repair' started by Michael, Jul 11, 2006.
  1. Michael
    Michael Guest
    This TV came in for an intermittent problem traced to bad joints at the
    degauss thermistor.
    However, while checking out the functions, I noticed that it skipped several
    channels, and all those between 46 and 61 (cable). I don't have the remote.
    The front panel has a "Function" button that brings up an on-screen menu
    that allows selection of cable or air input and has a line "Channel Select".
    I thought this latter might be an add/delete function, perhaps using the
    volume up and down, or channel up or down buttons, but it does not work. (I
    did try an One-for-All universal with it -- it works for routine
    functions -- but that didn't help with adding the missing channels.)
    Anyone know how to either reset the channel memory or to add/delete channels
    on this older 1988 model. (Other than this, the set is fully functional and
    has a great picture.)
    Michael C.E.T.
    (Please post reply, thanks)
  2. Guest
    I am having the same problem on my tv and haven't been able to fine a
    solution.
  3. jakdedert
    jakdedert Guest
    I had a Panasonic set which had the same problem. I don't have it
    anymore, so don't remember the model number; but when I did, I googled
    this group to find it was a known problem caused by a bad chip in the
    tuner.
    Likely you're looking at the same sort of issue.
    jak
