JVC / Sears 27" T.V.
Discussion in 'Electronic Repair' started by Dani, Aug 7, 2006.
  1. Dani
    Dani Guest
    Looking at the Sears site I can't locate any info, or parts on a model
    # 57-14367
    chassis # A 53, made by JVC TV Anyone have a cross listing for these
    Sears
    made by JVC units? It was dead horizontal output 2sd1878 was shorted,
    now
    it works fine, but the output gets hotter than it should, & there's no
    sound, but
    there is gain from the IC. Flyback # is CE42674. Dani.
  2. Jerry G.
    Jerry G. Guest
    Look up JVC in the Yellow pages, and give them a call to find their
    local parts distributor for your area. They will be able to sell you
    parts, and the service manuals.
    Jerry G.
  3. Actually, you are more likely to have luck with Sears for parts unless
    someone can cross it to a similar JVC model for you. This is one of the
    products that has Sears only support, IIRC. Sears has done this with
    several brands at times and the OEM will send you back to Sears for
    everything.
    Leonard
  4. sorsa
    sorsa Guest
  5. sorsa
    sorsa Guest
    send the sears model # and I can help you with info.I am sears av
    representative
  6. Dani
    Dani Guest
    I'm looking for a cross reference from JVC to Sears. I do JVC warranty,
    & they can't help. Dani.
  7. sorsa
    sorsa Guest
    what are you talking about,Dani?
    Doesn't exist a crossreference for tv models from jvc to sears.Sears
    models al builded by jvc,samsung and prima.So where is yours in this
    pot?
  8. sorsa
    sorsa Guest
    you should check with oscillo if the base signal is clean for the HOT
    and sometime a bad predrive trafo caused this heating.Or flyback is
    shorted.Is the flyback getting hot?
  9. sorsa
    sorsa Guest
    Do you need the characteristics for HOT or what?
