jvc AV32730 TV
Discussion in 'Electronic Repair' started by mneriv, Jun 7, 2004.
  1. mneriv
    mneriv Guest
    Worked fine last night. went to turn it on this morning and immediately
    turns off. happens weather I use remote or on/off button on tv.Picture
    doesn't even get to light up.
    Anyone have a similar problem?
    ed
  2. Jerry G.
    Jerry G. Guest
    In these sets, this may be a failure in the horizontal output stage or in
    the power supply, most of the time. There are many types of components that
    can cause a failure. You would have to give the set out for service, unless
    you are properly trained and equipped to do this yourself.
    Jerry G.
    ed
  3. b
    b Guest
    Not familiar with this model. Fault could be any number of things. In
    my experience, here are some of the main ones: capacitors in the power
    supply (easiest and cheapest to replace these first) / bad solder
    joint finally failed totally in hot areas like p.s.u. or deflection
    stage (very common)/ short on deflection or High voltage sections / A
    load on the line output transformer bringing the line down or causing
    p.s.u. protection mode..... also see the Sam Goldwasser repair faq
    if the set is fairly new and/or you don't feel you know enough to
    tackle the above then take it to a tech, as repair probably wouldn't
    exceed cost of a new set- if not, then dump it.
    good luck ,B
