JTC monitor flickering horizontal lines. Repair attempt and diagnosis
Discussion in 'Troubleshooting and Repair' started by Hlurion, Jul 10, 2021.
  1. Hlurion
    Hlurion
    Jul 10, 2021
    Greetings everyone! To cut the story short, monitor(AUO M270QANO 1.0 panel) I got has flickering horizontal lines( progressively worse to the left and top of the panel) which I have seen that probably has panel short circuit as a culprit and can be circumvented by cutting corresponding gate clock signaling(CLK) and that is what I indent to do. So the question is is there a way to know exactly what lines should I cut (maybe by using oscilloscope? ) or is it necessary trial and error? Also the backlight seems to heavily flicker above 78% brightness (78 and brighter) which seems to worsen the lines effect as well.. Here are some voltages and resistances to ground I measured.. Looking forward to your suggestions..
    [​IMG] https://imgur.com/6UEMHYi
    https://imgur.com/xgO8Rj9
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
