tspcrowther
- Feb 5, 2010
- 2
- Joined
- Feb 5, 2010
- Messages
- 2
Hello. I dont know much about electronics so please excuse any lack of basic knowlege or terminology.
I`m in the middle of building some precision simulator flight controlls using a usb interface from an old Saitek joystick. It requires 50K rotary potentiometers that have a specific angle of elecrical contact. Two 65 degree pots for the stick, 145 for the throttle and 45 for the rudder. Does anyone know where I might get some? or do they have a specific name? I`ve been looking for a couple of days and cant find much below about 220 degrees. And I`d like them to be much better quality than the originals. I`m also certain they would be linear pots.
As the interface uses all 3 pins on each pot, I tried a couple of methods to try and get the same results. First I mounted two standard 220k pots so they were joined, facing each other and offset at the required amount so I could get a reading of 0 to 50k on two pins of one pot, while 2 pins of the other pot read 50k to 0 and the mechanical movement was limited to about 90 degrees. But when this was wired to the interface and I tried to calibrate it, I was only getting about 25% of the required deflection in each direction and it was very jumpy... I figured I`d got this all wrong..
Desperatley now, I took apart a standard 100K pot, drilled a tiny hole through the outer track and bakerlite and fastened a tiny nut and bolt to get a good connection on the track. When I put this together It seemed to give similar readings as the original pots using my new 4th pin and it had a mechanical limit of about 120 degrees that was just about usable. But again when connected to the interface, although the results were much better, it was still quite jumpy and vague. Again, I was missing something.
Does anyone think any of these methods could work with a bit of tweeking? Or am I better off giving up and tracking down exact replacments?
Another possible option I`ve stumbled apon is a Hall Effect potentiometer... They are commenly availble in a variaty of usable angles and have the added bonus of being contactless... But, can they be used as a replacment for a standard pot?
Any help would be gratefully appreciated...
Cheers,
Paul.
Cheers,
Paul.
