T
Tim Shoppa
Al Cohen said:If I were looking for a firmware person, the most I could reasonably
expect them to understand...
A little on transistors. Transistors are usually brought in to boost
current-handling capabilities when op-amps can't cut it, although there
are many other uses for transistors as well.
An understanding of current-sourcing vs current-sinking, as well as
some of the tricks about mixing outputs with inputs is essential
for most firmware writers. These are not complicated subjects but
they do require some order-of-magnitude understandings of the
currents and impedances involved, especially when it comes to the
trendy-for-the-past-few-years push towards microamp level current
consumption in quiscient consumer devices.
If someone asks you to illustrate a LED driver and you need to solve
equations to come up with typical values, you're in trouble. Depending
on the employer there may be other areas where familiarity with actual
products would be good.
Tim.
