JK Flip Flop question
Discussion in 'Electronic Basics' started by pdx, May 13, 2004.
  1. pdx
    pdx Guest
    How is the truth table for a JK flip flop derived from the circuit? I don't
    understand it...
    TIA.
  2. Take a look at:
    http://www.play-hookey.com/digital/jk_nand_flip-flop.html
    Note that there are two separate set reset flip flops (cross coupled
    NANDs) connected in a loop by pairs of NAND gates. It functions
    something like a shift register, copying the J K states into the first
    RS flop during one clock state. When the clock goes to the other
    state, it locks out changes in that flop and passes its state on to
    the second R S flip flop. This lock and shift operation is what makes
    it edge triggered.
  3. John Larkin
    John Larkin Guest
    Does anybody still use JKs? I haven't used one in years, as a single
    part or in an FPGA.
    The classic TTL JKs would "catch ones"; if at any time the clock was
    high and the J or K inputs went momentarily high in the "flip" sense,
    it *would* flip on the next clock fall, even though the J/K had
    returned low before the clock edge. Confused a lot of people.
    John
  4. In John Larkin typed:
    Weren't there some that didn't ones-catch because they were made like a
    D FF with some input logic, so that if neither J nor K was true then the
    D input would revert to whatever level would not change the output?
  5. Fred Bloggs
    Fred Bloggs Guest
    This has nothing to do with the JK-FF. The original TTL family had many
    parts with a strict master-slave architecture that specifically
    prohibited certain input changes when the CLK was high. As for anyone
    using them anymore, the JK was THE FF of choice for ASMs, whereas the D
    FF was a natural for the much more versatile RTL architecture. The ASM
    generally requires far more self-discipline than the average
    semi-educated ape can muster, whereas the RTL is generalized enough to
    absorb even the sloppiest quasi-thinking, hence the popularity of D's
    and scarcity of JK's.
  6. John Larkin
    John Larkin Guest
    Absolutely right. Really smart people always do things the hardest
    possible way, just to show to the rest of the world how smart they
    are.
    John
  7. In Fred Bloggs typed:
    What is this? Real-Time-Logic? Register Transfer Logic? Obviously you
    don't mean Resistor-Transistor-Logic because you use the term in
    contrast to ASMs, like some other high-level architecture.
  8. Active8
    Active8 Guest
    The same way that any truth table is derived. You list all possible
    inputs and don't care states and write the outputs.
    Ever think of changing your major to biz ad?
  9. When I used to do hardware (not my area of interest), I seem
    to remember that properly designed circuits with JK instead of D would
    help to save a significant amount of logic. Most of the circuits that
    I did were small (10-20 gates), and at that level, saving a few gates
    with a JK was definitely helpful. For 'random' logic, I seldom saw
    a real reason for NOT using a JK. The major reason for not using a
    JK might be related to a lack of understanding or 'design concepts'
    to fully utilize them.
    Nowadays, the times that I'd use a CMOS/TTL (non FPGA/PAL/ROM or
    microprocessor) logic based design would be very limited.
    John
  10. John Larkin
    John Larkin Guest
    In the early days of DTL/TTL/SUHL/Utilogic, there was no standard for
    whether the active edge of a clock was the rise or fall. Discrete
    transistor flipflops tended to be NPN with diode steering logic, which
    was falling-edge stuff. JKs tended to clock on the fall, and Ds on the
    rise. Clearly you can't design clean synchronous logic with mixed
    clock edges, and rising won, so the JKs were on the losing side.
    FPGA state mechines now tend to be one-hot structures, not classic 2^n
    flipflop thingies, and d-flops driven by lookup tables (disguised as
    and gates) is a real clean way to do things.
    John
  11. Tam/WB2TT
    Tam/WB2TT Guest
    You always had to read the fine print with JKs. As I recall some JK that did
    ones catching on the J and K also had interaction between the clock and the
    set/clear inputs.
    Tam
  12. I certainly admit that some of the JKs had 'personality', but there could
    be substantial gate savings when using a JK vs D 'random' logic design. If
    using a microcode rom (or equivalent), then the benefit probable became nil.
    So the death of the JK advantage probably appeared with the use of large
    ROM type devices (or the mostly better yet programmable logic or PAL
    stuff.) AFAIR, many old design techniques made some of the
    hazard issues alot less troublesome than if doing ad-hoc designs. One
    always has to carefully review the eccentricities, however.
    It has probably been 20yrs since my last state machine design with
    traditional (now probably ancient) random logic. The amount of flexibility
    provided by microprocessors (and/or gate arrays of one kind or another)
    would probably push the random logic designs (e.g. with ASM type techniqes)
    into a very narrow niche. Way back when I did some sequencer designs
    in hardware (before significant tools were commonplace), the similarities
    between hardware and software were apparent.
    The discipline of using well architected 'state machines' in software
    or in hardware does translate to/from the simple logic designs of the
    past (e.g. where one might use a JK) through a state machine that would
    implement an internet server. An ad-hoc programming technique could
    certainly cause quality problems in a product, and the hazards of
    an ad-hoc hardware design can also cause 'problems.'
    Again, I saw the 'advantage' of using JK flip flops as mostly a gate
    count economy (where it might have been a little false because of the
    complexity of the JK flip-flop interface.) D flip flops were certainly
    more intuitive, but all but one or two designs that used JKs were
    designed using well structured techniques.
    (Using SSI 'gates' might have given a speed advantage in the early
    1980's for simple designs, but it is incredible that in the 10-20nsec
    for propagation in a saturated logic gate a Pentium4 can probably
    do approx 10 floating point multiplications. A 74ls (or even 74AS) cannot
    do much in the amount of time that a P4 can do a significant amount
    of computation.)
    John
  13. Tam/WB2TT
    Tam/WB2TT Guest
    Using CPLDs and gate arrays does not automatically eliminate JKs. The Xilinx
    software, for instance, has models for JKs.
    Tam
  14. John Larkin
    John Larkin Guest
    There's no reason to associate JKs with synchronous state machines and
    Ds with ad-hoc async logic.
    John
  15. I didn't mean to do so -- but D flip-flops seem to be easier to
    conceptualize with ad-hoc designs (probably due to avoiding structured
    design techniques.) Really, back when SSI (esp TTL) was common, there
    was almost NO excuse for using D over JK in random logic, except where
    there wasn't an improvement in gate count.
    For cases where the chip cost of JK doesn't create an advantage (probably
    nowadays where the logic cost is more on an actual gate count and not chip
    count), then the advantage of JKs is probably lessened.
    In a way, a JK was a way of packing just a little more logic into the
    flip-flop chip.
    John
