T
Tim Dorrington
Hi - 2 questions that I'm hoping you could help with...
1) I'm designing a circuit which currently uses half a CMOS 4027 dual
JK flip-flop. I need to add a monostable circuit to it, so that I get
a clean pulse (0.5 seconds approx - timing not too important) suitable
for clocking a counter IC from a push switch. I was going to use a
NE555 but wonder if there's a way I can use the other half of the 4027
instead? I assume that the push button will control the clock input,
and there would need to be some sort of R-C arrangement between the
output and the J/K inputs...?
2) If there's a possibility of someone touching a contact linked to a
CMOS IC's input, is there a simple way of preventing/limiting static
damage to the IC? The application is a game where the player might
cause a 2 contacts to touch (one for the IC input, one for the supply
voltage).
Thanks for any information,
Tim.
voltage).
Tim.
