I was just letting the thread run for awhile, for amusement value.
i can accomodate you. i found something so amusing i wish my scanner ran
on OSs older than win98, so i could post the side by side for
comparison. haven't got around to connecting it to the Linux box yet.
i'd have to load Sane and i'm anything *but* sane right now.
Now I'll have to try and remember what the hell I was doing nearly 40
years ago ;-)
don't feel bad, i'm having to look up crap i haven't touched in years.
expanding sin(theta).sin(theta + deltaTheta), integrating over 0 to PI
and dividing by PI didn't do it.
but since you want amusement, i did come up with something else.
where you started with
Vp.Vf.(delta_Theta).Kv/s and rearranged to get
theta_vco/theta_ref... your xfer function,
i'm not sure why you did that at all. using the delta_Theta term, that
is.
not being able to pull the cobwebs off the brain, i just took
G(s)
theta_vco(s) = ------------- . theta_ref(s) and plugged in
1 + G(s)H(s)
Vp
Kp = -----
PI.Re
Kf = what you had *after* i verified that
K(s+a)
G(s)H(s)= ------ ; i.e. Type II system
s^2
indicated a filter of the form
s + a RzCs + 1
Kf = ----- = --------
s Cs
Kp.Kf.Kv
so G(s) = --------
s
and H(s) = 1 ... there's something missing from your method... the
feedback function, not that it matters when it's 1.
and i got the same answer for theta_vco/theta_ref as you did.
how the hell those answers work out the same when i used the classic
closed loop xfer function and you used the open loop transfer function
(?) multiplied by delta_theta is beyond me. or does the inclusion of
(theta_ref - theta_vco) in your xfer function somehow *effectively*
close the loop? i can almost see that.
if you want to see the whole work, i'll show ya. somehow ;-) i can see
how the math works. in line 2 of your work, you've rearanged the eq so
that you end up with 1 + G(s)H(s) on the left side. it's *emerged*, so
to speak. it wouldn't have happened if you hadn't included
(theta_ref - theta_vco) in the whole mess.
was that amusing enough? did you spray some WD-40 on your time machine?
careful, 40 years is a long time... your flux capacitor may be dry
add booze?
Best Regards,
mike
