JFET question
B
Bo
I have a common source n channel JFET circuit--
with R1/R2 bias divider R1 = 420K, R2 = 180K
RD = 2.7K
Rs = 2.7K
RL = 4K
cap Cs in || with Rs.
Vp = -4
early voltage = 125
Idss = 12mA
How can I find small signal voltage gain @ mid freq?
I try to compute gm-- but need Vgs to do so. Do I assume Vs = 0 since
Cs short @ mid freq and then use dc value of Vg (6V) to say Vgs = 6v?
I'm thinking there has to be additional info to figure this out...
Any clues appreciated...
Bo
H
Helmut Sennewald
RD = 2.7K
Rs = 2.7K
RL = 4K
Vp = -4
early voltage = 125
Idss = 12mA
I try to compute gm-- but need Vgs to do so. Do I assume Vs = 0 since Cs
Bo
Hello Bo,
It's easy to calculate the gain.
G = gm*RD||RL||rd
Just forget the output resistance rd, because
it's much higher than RD||RL.
Calculate the DC-current Id.
Go to the datasheet and look for gm(Id).
G = gm*RD||RL
That's all
Helmut
Jon Slaughter
RD = 2.7K
Rs = 2.7K
RL = 4K
Vp = -4
early voltage = 125
Idss = 12mA
Bo
Did you try google?
http://www.ele.auckland.ac.nz/archives/design/tools/ampfet.htm
http://www2.eng.cam.ac.uk/~dmh/ptialcd/spice/simulation.htm
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/fet.html
and many more...
B
Bo
Thanks to all for your replies...
I finally found something via google that helped me. Ended up
calculating Vgs from a quadratic equation...
I could not look up in datasheet because P/N is unknown...
Thanks again,
Bo
