E
Eeyore
tempus said:Hi;
Is there a way to figure out the R(on) of a JFET when this parameter isn't
specified in the data sheet?
Measure one ?
Graham
tempus said:Hi;
tempus said:I mean before I place the order.
tempus said:Thanks John. I was thinking there must be some way using Idss, but I wasnt
sure which V to use. So for example from this data sheet:
http://www.fairchildsemi.com/ds/FJ/FJN598J.pdf
it would be 1.5V/350uA = roughly 4.3 megohms.
I must be doing something wrong. Can you set me straight?
Well maybe you're looking at a generic JFET which is on and you musttempus said:Hi;
John Larkin said:Yup, he did make a truly bad guess, off by roughly 50:1.
Why not use a cmos analog switch like an HC4066?
Why not bottom post?
John
tempus said:Wow thats awful..
I'm looking for a JFET to switch a guitar signal in and out of effects
pedals. I'll need 8 in total, but the signal will only ever be passing
through 4 JFETS at any 1 time. I am going to bias the drain and source at
1/2 V+ (4.5v in this case) and would like to switch the JFETs on and off
using a PIC. Since the PIC runs at 5v, I'm assuming it's control outputs
will also be 5v, so I'll need a fairly low Vgs off to switch the JFETs
completely off to isolate the effects from the signal chain when I want them
bypassed. I realize the Ron doesn't need to be extremely low (although the
lower the better, I suppose) but I also need the lower Vgs off. I'm trying
to find a nice balance between those parameters.
John said:Yup, he did make a truly bad guess, off by roughly 50:1.
John said:Don't people already make thumpless analog switch chips?
Led-photoresistor things could be interesting.
tempus said:Actually I breadboarded my design using an MPF 102, since it was all I had
lying around. Unfortunately, it has a Vgs off of 8V, so it didnt provide
great isolation when it was off. You're suggesting a MOSFET also? I've got
some BS170s lying around so I'll do some work with them.
Tim said:I've seen circuits that start with a series resistance and a switch that
shorts out the signal when it's on -- these will handle higher voltages,
and you can follow that with another switch that turns on/off to finish
the job (although you'll then have to make sure that you've turned it on
enough for that several-volt swing). Such things are fairly typical of
RF circuits that use PIN diodes for switching, although I think I've
seen it in audio paths.
I'd consider attenuating the guitar input to something guaranteed to be
manageable by the switch, but I don't know if it'd get past the "better
make sure this won't cause problems" stage of the design process.
Actually I breadboarded my design using an MPF 102, since it was all I hadTim Wescott said:So what's the matter with an MPF-102? Not available?
MOSFETs will work, too.
CMOS switches will probably provide soft switching if you ramp the
'enable' input -- the simpler ones are just a pair of MOSFETs with
none-too-spectacular Rds-on figures.
