Jerry can fuel tank fittings
Ig,
Good photos!
The fittings you are using for your fuel hoses are intended for air
line quick-connects. I recommend you get hose barbs instead. They
are available in both male and female threading, like you used.
Otherwise, nice work!
Tom Willmon
near Mountainair, (mid) New Mexico, USA
Net-Tamer V 1.12.0 - Registered
B
Bruce in Alaska
Ignoramus23411 said:
I have a question about hose barbs. Once I put the hose on, without
clamping it, just how difficult is it to pull it off?
Thank you!
i
Hose Barbs are ok but what you nreally want is the Hydrolic Type Quick
Disconnects that have a check valve built in both sides. That way you
don't need the ball valves on the hoses. They should be available
from any Hydrolic Supply House.
Bruce in alaska
Similar threads
C
Replies
Views
902
Curtis Brown
C
W
Replies
Views
955
William P.N. Smith
W
Replies
Views
836
Jan Brock
R
Replies
Views
1K
no useful info
N
