Jensen TV blue screen problem
Discussion in 'Electronic Repair' started by [email protected], Jun 1, 2008.
  1. Guest
    Hi group. I have searched for threads and came up empty on this set.
    Same with my repair database. This is a model #TS2050J. Televsion was
    working fine. Unplugged it, moved to another room, plugged back in and
    now only get a blue screen at power up with a display "C24". I don't
    know what this means. Left set unplugged for 24 hours and tried again,
    with same results. Is this a micro problem or something I can reset.
    Buttons on the front panel don't respond. Also don't have remote, and
    can't find code for my all in one. Anyone here have a guess as to what
    I should check? Thanks as always.
  2. Deke
    Deke Guest
    Do a Google on Jensen TS2050J.
    You will find that it sold new for $95 at Best Buy, where to
    get a replacement remote, its a Made in China elcheapo TV, and it has a poor
    performance history.
    Good Luck!
  3. Guest
    Thanks for the reply. This set was given to me to work on and keep.
    Original prolem was no power up, but it worked fine when I got it
    home, until unplugged as stated above. I suspect maybe an eeprom or
    micro problem, but don't know if this is a common fault with this
    particular set. I'll do some more surfing and see what I come up with.
    Thanks again.
  4. Colleen
    Colleen Guest
    We have this tv, and the "C24" means the TV is set for cable input,
    and is on channel 24.
