Jean monitor E-W problem and damper diode equivalent?
Discussion in 'Electronic Repair' started by Gary, Nov 6, 2003.
  1. Gary
    Gary Guest
    I've a PC monitor which doesn't allow any E-W adjustment, so the screen is
    always far too wide.
    Main suspect is the damper diode 5TUZ47C which I cannot locate a source of -
    anyone know of an equivalent?
    FWIW, the relevant circuitry is here:
    http://www.franklin49.freeserve.co.uk/jeanmon_h.gif
    Note that R422 - 3.3R was overheated and very high resistance, I've also
    replaced Q412 - IRF630, so am assuming the diode, or maybe C418, are at
    fault, but any other suggestions will be most welcome.
    Regards
    Gary
