isolators
Discussion in 'Boat Electronics' started by Steve Lortie, Jan 22, 2006.
  1. Steve Lortie
    Steve Lortie Guest
    I'm starting to give some thought to my power source on the house boat I am
    refitting. I am leaning towards using isolators to seperate the battery
    banks. I would like some experienced feedback on what type of isolator to
    use; diode, FET or solid state? All I know at this point is that the drop
    across the diode type can play havoc with the battery life because of the
    voltage drop never allowing a full charge (?). The other two kinds I have
    not been able to get anything except that they have a much smaller v drop
    (FET) or none (solid state). And that is from sales materials. Will using
    isolators allow me to forgo the 12Both switch and just use an in line on/off
    switch?
    May seem like a dumb question but how do I know what size of charger I will
    need or does size (amps) matter other than how quick it will charge the
    batteries. I plan on having two start and two house batteries.
    How important/neccessary is it to have a galvanic isolator on the AC side?
    THX
  2. Take a look at www.smartgauge.co.uk you will find most of the answers
    there!
    Look at the "technical" section.
    BTW IMHO a solenoid based split charge system beats a diode system.
    Again all answers above.
    Richard
    Nb "Pound Eater" Parkend G+S
    Please remove your hat when replying
