Just a general question, with the grey silicone isolation washers, would you use them dry, or with thermal compound ? I know with mica washers you should use thermal compound. But watching Dave Jones on the eevblog on his adjustable current source he made, the power devise was mounted dry, but in that instance no isolation washer.
If you need to isolate are the grey silicone isolation washers ok to mount dry ? I have googled this with no helpful results. Thanks for reading, any advise appreciated.
