H
Hammy
I have a 450VA isolation transformer. The transformer is supplied from
a three prong outlet. I've taken some measurements with my DVM they
show a voltage between lines to ground on both outputs. The combined
voltages between both lines to ground don't even add up to the line to
line voltage.
Heres a schematic of the measurements.
http://i32.tinypic.com/x4ns47.png
I just got this transformer but I've already used it to test a few
line powered circuits. These measurements must be wrong or I would
have blown fuses when hooking up my scope to the circuits.
I use the isolation transformer on the test circuits not on my scope.
For example if I were to hook up a flyback to the isolation
transformer and use my scope (un-isolated) to take primary side
measurements according to those measurements I should be getting a
short through my scope ground lead. This hasn't happened both the
isolation transformer and the flyback are fused; neither blew.
Can anyone explain this?
line voltage.
