Isolating electric shower
Discussion in 'Power Electronics' started by Keith Jackson, Feb 12, 2019.
  1. WHONOES
    WHONOES
    856
    206
    May 20, 2017
    Have a pump fitted between the hot tank and the shower also the incoming cold supply for the shower as well. Works perfectly. And I live on a hill.
  2. Bluejets
    Bluejets
    3,977
    820
    Oct 5, 2014
    AS Alec-t says, you have a flow problem which was why I originally said get some new pipes.
    If you have sufficient pressure for the shower alone, and then it drops when another tap turns on, that's a flow problem, not pressure.
    Any amount of pumps is not going to cure that.
    Which means the pipes are too small to begin with or if they are gal pipes or whatever, probably rusted up internally over the years.
  3. duke37
    duke37
    5,330
    750
    Jan 9, 2011
    There is obviously a flow problem so that the shower and a running tap can not be adequately supplied simultaneously..
    I suggested a pump to supply the shower which will starve the running tap of its supply and give priority to the shower.
