V
vonroach
1/0 is a small number?
No it is meaningless gibberish.
Confused is too mild a term. If y = 1/x. then y goes from1 to a veryYou're confused. If y = 1/x then y gets pretty big when x gets pretty
small.
There isn't one. Division by 0 is meaningless.Then what would be the proper way to write it, please?
Both are meaningless. Just crap piled higher and deeper as in Ph D.Write what? That 1/x gets big as x gets small?
1/x -> +infinity as x -> +0
1/x -> -infinity as x -> -0.
But for me that is not the issue. I do not LIE on newsgroups - there is
no point - but I do make mistakes; everyone does. I suggest that your
So you think the polynomial 2 x^2 + 3 x^1 + 4 x^0 is undefined at x=0 ?
x^0 = 1 except when x=0 which doesn't exist.Besides, there is also the definition from algebra, in which x^n is
defined whenever x is a member of a monoid M and n is a natural number.
In particular, x^0 = e, the identity in M.
The point is that you can't cancel them when x may be 0, because
division by 0 is undefined.
However, in the lim x->0 case x approaches
0, but never really equals zero, so the cancellation may be performed.
vonroach said:Otherwise? Accept your opinion? Crazy George is really crazy!
[/QUOTE]John Fields said:On Tue, 28 Dec 2004 22:13:54 -0000, "George Dishman"
So far you are assuming the result you are
trying to prove, that the ratio of numerator
and denominator is to be 1.
I like that however while the statement 0=0
is obviously true, it isn't exhaustive. We
also have
0 = k * 0
hence by your method
0/0 = limit as x->0 of (k*x)/x
hence
0/0 = k for all constant k
You still fail to prove the claim of
uniqueness for the value of 1.
so my method first reduces k*0 to 0
by virtue of the multiplication, then the division by zero is
performed to yield the ratio of 1.
(k*0) -> 0
------ --- = 1
0 -> 0
Interestingly, your method also requires the quotient of 0/0 to be 1,
otherwise the multiplication by k wouldn't yield k as the product!
since said:.. That, I believe, proves my point, my point being:
x
y = lim x->0 --- = 1
x
John Fields said:---
And there's the rub! My point is that it _should_ be defined, and
defined like this:
0 1
--- = 1, --- = oo,
0 0
If we say
x
y = lim --- = 1
x +oo -> -oo x
Then y will be equal to 1 for every instance of x except when x
crosses over from + to -?
In my view that's preposterous, and the mere parroting of "division
by zero is disallowed because it's undefined" a convenient dodge.
I don't have a problem with either, but it seems to be skirting that
taboo point where x = 0.
) about 'Is zero even or odd?', on Wed, 29 Dec 2004:
--- = k
for all finite k.
And that's nonsensical.
It gives us, for example,
1 = 0/0 = (0+0)/0 = (0/0) + (0/0) = 2
You eventually lower the voltage to 0V.
That's what I achieved with the short.
The proper circuit:
+---(V)---+
(-)---o---[R]---o---(A)---o---(+)
Will yield the proper results if examined using Ohm's law.
Assuming that the voltage across the resistance is 1V and the current
through it is 1A, then the resistance will be:
E 1V
R = --- = ---- = 1 ohm (1)
I 1A
Assuming that the voltage across the resistance is 2V and the current
through it is 1A, then the resistance will be: 2 ohm.
I am trying to illustrate that I can make a point that 0/0=2.
You cannot discard my point without adding extra information about your
set of conditions.
This extra information is not present in the 0/0 term, but it _is_
explicitly written in lim x->0 x/x and lim x->0 2x/x , respectively.
You want 1 ohm, that's what you bring into the computation. You're
setting everything up so that 1 ohm results, which means it's circular
reasoning.
If you hadn't set everything up that way, the 0V/0A measurement would
leave you stumped as to the value of the resistor, and 0/0=??? then.
Again, the set of values that are divided by itself is x/x for all x in
R\{0}, and lim x->0 x/x = 1 as well.
You are doing the limit argument nicely.
Now you arrived at x=1 not by dividing by 0 outright, but by taking
larger values and going closer to 0. I would explicitly write what you
did, so your last formula would change to
r
x = lim --- = 1
r->0 r
This is mathematical shorthand for your reasoning that any nonzero value
plugged into r/r is 1, so it makes sense to take r/r=1 for r=0 as well.
You misunderstood my point. My point is that you have to arrive at x/x
or r/r before you plug in the zero. Conmsider: if you had x=2r/r, put in
r=0 to get x=2*0/0 and use 2*0=0 to simplify to x=0/0, then the
numerator is algebraically 0=2r and the denominator is algebraically
0=r, and then
2r
x = lim ---- = 2
r->0 r
which would lead you to conclude that 0/0=2, in this case. You set your
case up so that x=r/r, i.e. numerator and denominator are algebraically
the same *before* you plug in the zero.
This is not true for R=E/I, which is why you can't make a measurement in
the E=0, I=0 case (unless you have extra information).
You seem to grasp that so well. You can certainly measure 0V and 0A, but
you can't determine R. For what reason do not grasp the analogy that 0/0
represents the same condition in mathematics?
I read in sci.electronics.design that John Fields <jfields@austininstrum
I think this thread has shown that there are two sorts of people, those
that associate taboos with 0 and those that don't.
My view is that logically-inferred values of expressions involving zero
should be accepted unless they result in contradictions. I do not
support a priori restrictions on interpretation, and I do not accept
that 'undefined' is a valid show-stopper.
Sigh. Forget machines. Is the definition of division clear to you?
the result of the division a/b is such a number c that c*b = a.
That's *all* there is to it. So, the result of 0/0 is a number c such
that c*0 = 0. Can you tell me what c is?
OK, here is a little exercise for you. At x = 0, sin(x) is also zero.
And, so is any positive power of either x or sin(x). So, using the
Taylor expansion for sin(x), evaluate the following limits:
1) lim_x->0 sin(x)/x
2) lim_x->0 sin(x)/x^2
3) lim_x->0 (sin(x))^2/x
Chuckle....0/0 is meaningless and you are wrong and bordering on
lunacy.
George said:<snip> hence
--- = k
for all finite k.
