"Gary Woods" bravely wrote to "All" (21 Nov 03 16:36:18)
--- on the heady topic of "Re: Is TV coax impedance important?"
GW> From: Gary Woods <
[email protected]>
GW> Subject: Re: Is TV coax impedance important?
GW> Xref: aeinews sci.electronics.repair:12107
GW> "Jerry G. said:
If the impedance is not matched, the length is short, and the signals are
strong, you will not see any losses. But, these errors will add up.
GW> There's a worse problem: If the line is not 75 ohm and the length is
GW> non-trivial, you'll get reflected energy that will show up as ghosts.
GW> Ungood.
One can match a load to a different impedance using a 1/4 wave length of
a different cable impedance, the value of which is the square root of
the former products, but the 1/4 wave only works at one frequency.
Another related method is the "series-section transformer" (the
equations are too big to include here). But for broadband one needs a
transformer with the right ratio.
Asimov
.... Reactance: your imaginary friend.
