Eddie_moramora
- Sep 5, 2014
- 5
- Joined
- Sep 5, 2014
- Messages
- 5
I am new to the world of electronics & have no clue if this is possible but basically I have a small project in mind and I did some research on parts out there.
So what I'm trying to do here is have these parts connected (like in the picture) so that the Hall Effect Sensor acts as an ON switch to trigger the motor (either DC or Servo) then the Flexiforce Pressure Sensor will act as a stop for the motor once it reaches 1lb-2lb but I would still like for the Forward/Reverse button to control the motor even after the pressure is reached by the Flexiforce Pressure Sensor & if possible to have a Battery Indicator that will also act as a Pressure indicator for the (Flexiforce Pressure Sensor) . It would be great to power everything with a Polymer Lithium Ion battery & have it be rechargeable.
I know there's more to this than just connecting parts but thats where I need help first and foremost is this possible ? what kind of breakout board or micro controller will be the most effective?
Any information is much appreciated thank you.
