rescueweasel
- Aug 29, 2014
- 1
- Joined
- Aug 29, 2014
- Messages
- 1
I have a small CNC router that uses mach3 and the program turns on and off two switched ac outlets to control the vacuum and the router during cutting.
I have a small cutting laser which I want to attach to the gantry and use to cut, but it runs off 12 volts. I want to have its power controlled the same way as the router by the machine.
I hooked up an ac to dc converter and it powers the laser fine but the problem is that there is a lag coming on and the power tapers off when shut down. I need instant on and off of the 12 volts.
Is there such thing as a relay that I can have 12v in and out but have a 120v ac trigger? Or is there something better I could use.? The laser draws about 2.5 amps at 12 volts.
Thanks for the help.
