Is This A Damaged Connector?
Discussion in 'General Electronics Discussion' started by buhuehue, Apr 15, 2017.
  1. buhuehue
    buhuehue
    3
    Apr 15, 2017
    http://m.imgur.com/a/uz1RO
    [​IMG]
    sorry for my bad english and if this is wrong section
    on the second picture you can see the connector missing 1 copper on the circle.
    is there a chance that the connector normally like that or because the connector is damaged.
    if it damaged,is that small damaged can make the connector malfunction?because theres a problem in my laptop and im not sure is it because of that connector
    (i know nothing bout this thing)
  2. Alec_t
    Alec_t
    3,137
    852
    Jul 7, 2015
    Welcome to EP!
    The image link is broken. Post the image to this site using the 'Upload a file' button.
    davenn likes this.
  3. davenn
    davenn Moderator
    13,984
    2,015
    please repost image by uploading to forum
    I went to your image upload site and found your pic ... it is way to difficulty to see
    you need to take another MUCH CLOSER in pic of that white connector
    WELL LIT and SHARP
    @Alec_t it helps to quote the person when you make comments like that so that they get a quick notification that their post has been responded to
    else it could be days before he just happens to check back
  4. buhuehue
    buhuehue
    3
    Apr 15, 2017
    [​IMG]
    [​IMG]
  5. davenn
    davenn Moderator
    13,984
    2,015
    so is there a wire in the cable that should go in there ?
    it may just be an empty spot
  6. buhuehue
    buhuehue
    3
    Apr 15, 2017
    there's no cable that go in that slot
  7. davenn
    davenn Moderator
    13,984
    2,015
    OK shouldnt be a problem then
