is there a address bus switcher???
Discussion in 'General Electronics' started by Ravindra, Jan 3, 2004.
  1. Ravindra
    Ravindra Guest
    hey i am designing a microcontroller system that uses a ccd and memory
    to store the image.
    i need something that selects an address bus from two separate 16 bit
    address buses. curently,i am using two tristate latches whose outputs
    are shorted.
    i also need the reverse thingy..a component that connects a bus to any
    of the two output buses depending on the select line.again ,here i am
    currently using two latches.
    i know that what i am talking abt correlate with mux-demux but i need
    16bit and 8 bit version of the component. i tried searching on the net
    but ended up on a page where some other person is looking for a
    similar thing.
