Jim Thompson said:
On the open-battery condition, yep.
The magnetized rotor has a draw-back, but GM calls it a "feature"...
daytime headlamps to absorb the unregulated output that results from
the magnetized rotor ;-)
The excess current produced by this magnetized rotor is small, unless the
engine is up in the 5000 - 7000 rpm range (most older GM engines are not
revved beyond 3000 rpm under normal conditions), even then it's not much.
The ign system, Computer, 6 injectors and especially the MAF sensor is more
then enough to drain this current in my car without daytime running lights.
In a old car without a computer system (including a computerized feedback
carb), this bit of magnetism might put a little excess strain on the battery
(breaking down the water - commonly called boiling the battery due to the
hissing sound), especially back then a typical lifetime for a battery was
about 4 years. My father has a old work van that is only the basics (carb
and ign, no DRLs) from 1984 and surprisingly enough, the voltage is well
regulated to a stable 13.8 V under only ign system load to full lights and
front and rear heater blower motors going full blast. The last battery
lasted about 7 years. These days the engine management systems, climate
control systems, DRL's etc keep more then enough load on the alternator. One
not so interesting part about GM is that their vehicles are increasingly
getting crappier as they try to cheapen designs as much as possible and
switch to imported sources for their parts. My old 1985 MPFI Chev (GM
division) Camaro is very reliable, required very little maintenance, even
with the extreme abuse I put on it at times (I did manage to blow a
synchronizer in the transmission on 2nd gear which took about 4 hours total
to fix, and I did rip a bracket off the rear end due to extreme abuse and
rust). It's age is really starting to show (very hash winters here that love
to eat metal - refinishing a car every so often takes its toll, and a lot of
little things are starting to need replacement) so I will be replacing it
likely next spring/summer. It's replacement won't be a newer GM.
Jeff (former nic "Da Man")
