Is that a fuse or resistor
Discussion in 'Troubleshooting and Repair' started by pharaon, Jun 20, 2020.
  1. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    Is that blown item is fuse or resistor, and is it possible to replace those SMD didoes with usual one?must the four bride SMD didoes be replaced or can i replace only two that is faulty with regular 1n4007
    [​IMG]
    [​IMG]
  2. Bluejets
    Bluejets
    4,851
    1,016
    Oct 5, 2014
    Probably both, a fusible resistor.
    Not common to replace just individual diodes in a bridge.
    Space might be a problem replacing with axial type diodes.
    I'd say some other fault there as well, not just the ones you point to.
  3. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    That fusible resistor and two smd diodes,
    What item should I use for that fusible resistor cause I can't find the same should I use fuse or resistor
  4. 73's de Edd
    73's de Edd
    3,104
    1,312
    Aug 21, 2015
    Sir pharaon . . . . .
    Correct, in that units Surface Mount . . . M7's . . .equate in electrical equivalency to a leaded general purpose 1N4007 diode .
    You could ease the sharpness of bend at the case and form into this *** shape, to get two folded under tabs to solder to the foil lands. You PRE TIN both the lead tabs and the foil lands by adding fresh solder to the foil tabs and then micro position and reflow solder them .
    OR . . . . you could fold a diodes end lead over and mount them vertically, such as the F1 resistor is now done.
    Just don't get so DEEPLY engrossed in the mounting aspects, such that you acidentally get 1 or more diodes polarity-(ies) installed backwards . . . . . . the power supply . . . . . it then go BOOM ! ! ! . . . . on power up.
    Replace all 4 of the original units in order to maintain a "balanced" set of 4 new diode junctions.
    Your pic didn't quite all encompass, in showing the MAGIC part number on the 8 pin IC nearby.
    It is probably enclosing a now dead shorted POWER FET built within it . . . . or else . . .that chip feeds over to driving a separate . . . . shorted out ? . . . .POWER FET.
    I wouldn't worry about that popped 10 ohm resistor for just now, and just wire in leads to a 60 watt incandescent lamp, until testing with it during power up, then reveals, no further defective component problems .
    Then, the use of a 10 ohm carbon film type would blow open at the lowest overload level of loading . . .fast acting . . ., whereas a metal film unit would give more time lag . . . .it appears that original unit is being metal film unit.
    Thaaaaaaaaaassssit . . . . .
    73's de Edd . . . . .
    I'm not a snob. . . . . . . I'm just better than you are.
  5. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    [​IMG]
    [​IMG]
    How to check the 8 pin IC
    Any picture for it or just regular resistor
  6. Bluejets
    Bluejets
    4,851
    1,016
    Oct 5, 2014
    Seems an odd-ball ic...nothing came up on a quick search....
    Test for any shorted pins...sometimes they use multiple pins for the mosfet so that might be an indicator...
  7. 73's de Edd
    73's de Edd
    3,104
    1,312
    Aug 21, 2015
    Gimme a good closeup of the other side of the . . .double foil sided . . . board so dat I can reads it . . . . .as it is now, a highly educated guess would be that it is a TNY 264.
    Thaaaaaaaassssssit . . . .
  8. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    Ok changed the diodes, I'm hearing like buzz from the circuit but no output Dc while connecting to 60 wat lamp in series
    It's a led light Power supply by the way
  9. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    [​IMG]
    [​IMG]
  10. 73's de Edd
    73's de Edd
    3,104
    1,312
    Aug 21, 2015
    Any chance that the secondary rectifier might be bad ?
    A double sided board in two shades of green mask with that style of vias is not too easy to read , but I made out the rank principals.
    WITH an additional major hindrance of not having board in hand to take ohms readings.
    The mentioned IC seems to fit to the board traces. I submitted a typical use/ application as the very bottom reference..
    There are aditionally the two SM low value . . .0.6 ohm . . . resistors being in a series loop within the power circuitry.
    There is the same R/C snubber and companion series damping diode, associated witth the primary of the transformer winding.
    There are the series pair of 510k " bump up " resistors to initially start up an AC powered down unit.
    The secondary has just a Schottky diode and its power reservoir filter E-cap and a 68K bleeder resistor.
    What are the two E-caps . . .on the primary and secondary . . . .their voltage and capacitance values ?.
    Particularly the secondary LED supply voltage as it might be supplying for either a 30-60 or 90 volt series configured LED string .
    ( But you have said no DC there. )
    A nearby lightning bolt to the power line was the probable cause of the units outage.
    If you are uncertain of the lamps LED strings condition . . .of having a possible open LED in the string . . . I would be using yet another incandescent lamp in their place. Then you would have some degree of glowing light level if they were receiving DC power from that secondary.
    Now . . . the already installed test lamp in place of the fuse might be cramping the supplies power output level. So if the F1 . . .test lamp is not BRIGHT . . . . AND your primary E-cap has lived thru having had RAW AC to it until F1 blew open .
    And you have placed an AM radio, tuned off from any stations on top of the Sw Mode power transformer and it is going crazy with radiated RF sub harmonics . . . . indicating a definite power swithching ction , occurring in the primary transformer circuit.
    Do a spot check of the DC output voltage at your V+ and V - terminals with a loading.
    If all seems to be somewhat normal you might chance a 1-2 second shorting across the test lamp to see if full power is permissible, and will run allright that way.
    If so, then temporariy use a 10 ohm carbon film for R1, for further protected voltage analysis.
    The floor is now open for further questions.
    BOARD REFERENCES . . . . .
    [​IMG]
    https://i.ibb.co/YXG3h9d/SMPS-LED-Supply.png
    FULL TNY 264 Data Sheet . . . . .
    https://datasheetspdf.com/pdf-file/798288/PowerIntegrations/TNY264/1
    Must have info . . . . A Cycles to Hertz Cross Conversion Chart:
    https://www.kb6nu.com/wp-content/uploads/2012/04/cps-hertz-chart.png
  11. Harald Kapp
    11,522
    2,654
    :);):p:rolleyes:
  12. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    No it's alright
    400V 15μf
    100V 22μf
    It's for 60V led light, I've tested with DMM and didn't get dc read
    I bought new LED string, but waiting to fix the power supply before I connect it
    I didn't put the lamp on the fuse place, I have it as AC in to the circuit so if there any short in the circuit it will light
    [​IMG]
    Yes, and also i could hear the buzz without the AM radio although it was very low
    Will try, but what kind of load?
  13. WHONOES
    WHONOES
    1,145
    313
    May 20, 2017
    You most likely need a load on the output for the switching circuit to work at all. Most of these types require a minimum load probably around 5% of rated output. Though having said all that I would expect to see some sort of voltage on the output, it would likely be very low though. According to the datasheet, the switching frequency is jittered at 1Khz which may account for what you are hearing.
    Further, The TNY263 has a Line under voltage detector that switches off the switching FET until the condition is corrected therefore, the lamp in place of the resistor on the input may be causing that problem.
    I suggest that you have a read of the datasheet (see below) which may help.
    https://www.power.com/sites/default/files/product-docs/tny263_268.pdf
  14. 73's de Edd
    73's de Edd
    3,104
    1,312
    Aug 21, 2015
    Sir pharaon . . . . . .
    O.K.
    you are being fine on having the lamp in series with the AC power into the unit . . . .that then will provide "blow up " protection to your unit at power up for initially testing the ¿ repaired ? unit.
    BUT . . . with your last photo you still have an open AC input circuit to the FWB rectifier configuration, just by virtue of there being no closed power input circut, via the missing F1 fuse resistor.
    SO just get installed, EITHER a carbon film or a metal film resistor of 10 ohms value . . . . .guesstimate the wattage by using the same size as the pulled unit . . . . . we'll then worry about the specific, proper, gold plated, diamond encrusted version LATER.
    As for the AM radio,I think that you were merely hearing expected AC line noise.
    With that IC circuit powered up and working properly, its strong radiated harmonics, that extend well on up into the Low RF spectrum, will DEFINITELY let you know that you truly have some SWITCH MODE power switching action going on.
    You can even further confirm this . . . . in showing your self WHAT sound your ears are expected to be hearing . . . . by using either a wall wart that is of SMPS design inside OR even some of our CFL or LED light bulbs and "kissing" them with your small radio. ( The SMALL radio aspect, is being in order to get right on in and being capable of being placed physically CLOSE to them. )
    Then, after hearing that aural effect, remove the power to the device and listen to the main filter capacitor drain down and cause a simultaneous SHIFT of the received tone downwards until it finally drops off. . . . . . and then there will be just the residual AC power line noise that you WERE hearing.
    Any sufficiently highly advanced modern technology is hardly indistinguishable from magic.
  15. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    i already connect the input after the fuse since i don't have the fuse installed on
    the noise were from the IC circuit not the AC line noise.that's why it keep getting slow on the radio till it fade out when i disconnect the AC power
  16. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    ok i tested with the LED strip and it work fine, you were right it needed a load to work
  17. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    So what exactly should I use, 10 ohm resistor 1 watt or regular fuse
  18. Bluejets
    Bluejets
    4,851
    1,016
    Oct 5, 2014
    The fusible resistor serves a dual purpose in that it reduces inrush at startup.......so both really.
    You do realise they are available in places like Ebay etc. ...?
  19. pharaon
    pharaon
    380
    6
    Oct 28, 2014
    i live in different country, and the charge to order from Ebay doesn't worth it
  20. bertus
    bertus Moderator
    1,877
    709
    Nov 8, 2019
    Hello,
    This video will explain the fusible resistor:
    Bertus
