Is Raspberry Pi and Arduino hardware compatible with the Chip?
Discussion in 'Microcontrollers, Programming and IoT' started by a.non, Aug 19, 2017.
  1. a.non
    a.non
    Jul 29, 2017
    Hi
    Would I be able to use a sensor that is marketed for Arduino/Raspberry Pi with the Chip GR8? I understand that the code would need to be modified and the form factor might be different but at a hardware level, there's no reason the hardware could only be made to work on Arduino or Raspberry Pi, is there? That the case wouldn't fit wouldn't be an issue as I could always make my own.
    I haven't bought any of them yet. If I start with Raspberry Pi, would I somehow be locked in to only buying add-on modules that are specifically marketed for the Raspberry Pi or would I be able to use Arduino sensors as well? Likewise with the Chip, would I only be able to use their own sensors or would I be able to combine the Chip with Arduino and/or Raspberry Pi sensors?
  2. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    Any sensor can be used with any processor - all that is required is to change the sensor output to a signal that the processor can accept, usually 0-5V or some serial data. As you surmise, coding changes are usually necessary too.
  3. a.non
    a.non
    Jul 29, 2017
    Thanks. That's what I thought, but some people seem to be under the impression that they can't mix and match. I'm happy to re-configure a couple of things if necessary.
  4. Irv
    Irv
    112
    30
    Jun 7, 2017
    Just be careful to check the supply voltage needed by the sensor(s). Some are 5v, others 3.3v. Some have a voltage regulator onboard, so they can use 5v even if they only run on 3.3v internally.
    Also, the output voltage needs to match the Arduino (0-5v) or the Pi (0-3v) input requirements.
    There are tiny, cheap voltage converters available for this purpose for digital I/0. For analog, you'll probably wind up making your own voltage divider if required.
