Is my schematic correct?
Discussion in 'General Electronics Discussion' started by FrankS, Apr 13, 2021.
  1. FrankS
    FrankS
    4
    Apr 13, 2021
    I have designed a simple circuit with buttons and leds to be used with a raspberry Pico board.
    Can someone advice me if this is correct so that I can order a PCB?
    Thank you
  2. davenn
    davenn Moderator
    13,901
    1,971
    well it would help if you showed us the circuit
    Martaine2005 and Harald Kapp like this.
  3. FrankS
    FrankS
    4
    Apr 13, 2021
  4. Harald Kapp
    11,813
    2,752
    Requires login - impractical. Please upload here as image. File size <300 kB should work well.
  5. FrankS
    FrankS
    4
    Apr 13, 2021
  6. Bluejets
    Bluejets
    5,158
    1,077
    Oct 5, 2014
    It is more conventional ( and less troublesome) to add pull-up resistors in software and to run switches to ground.
    Naturally alter code to suit.
  7. Harald Kapp
    11,813
    2,752
    • Power supply to the chip is missing.
    • Bypass capacitor on the chip's power pins is missing.
    • Buttons lack a pull-down to draw the input to GND when not pressed - unless you can use internal pull-down resistors at the GPIO pins.
  8. FrankS
    FrankS
    4
    Apr 13, 2021
    Thank you all for your suggestions.
    I should clarify that I do not propose to use the RPI2040 chip but the board like in the pic below
  9. bertus
    bertus Moderator
    2,162
    810
    Nov 8, 2019
    Hello,
    Without the code, we can not tell if the right connections are used.
    In the code the inputs and outputs must be declared.
    Also what should happen with the leds and switches is in the code.
    Bertus
  10. Harald Kapp
    11,813
    2,752
    Pull-up or Pull-down resistors for the buttons are missing anyway. You can use internal pull-ups or pull-downs on the processor, but you need to declare the use of these in software, see here (with the button connected to 3V3, pull-down is what you will need).
    Also you may want to or need to debounce the buttons. This example is for the raspberry Pi 4 but the principle is the same for the pico.
